#4098 - 01/26/25 03:27 PM Sidekick not showing "Router" data?
zeth07 Offline
I just recently bought access to the Sidekick thing and for whatever reason it's not actually showing anything for my router data?
I can't imagine this is normal but I don't know if maybe there's something I'm missing for why it's not doing it?
EDIT: Also ever since I added the Sidekick PingPlotter is now showing nearly 50% Packet Loss to my 1st hop/router at all times when it never showed packet loss to the router before.
Edited by zeth07 (01/26/25 04:57 PM)
#4100 - 01/27/25 07:14 PM Re: Sidekick not showing "Router" data? [Re: zeth07]
Hey Zeth,
The next time you open Sidekick, you should be able to get the router target started by navigating to the "Configure" tab in the top right corner, followed by "Reset a Target" and then restarting the router. If this doesn't work please reach out to us in an email (support@pingman.com) and we can take a closer look using your email (so you don't have to share that info here).
As for seeing packet loss at your router, it sounds like with the additional packets from PingPlotter/Sidekick the router may be prioritizing timed-out ICMP requests differently. This is normally done to accommodate higher-priority traffic. The important thing to remember is that as long as the final destination looks good, what happens earlier in the route can be ignored. This concept is covered in more detail in the following article:
https://www.pingman.com/kb/article/one-poorly-responding-router-5.html
Let me know if this leaves you with any additional questions!
0 registered (), 76 Guests and 1 Spider online.
